Washing machine door lock checking
Old 12-14-12, 01:10 AM
T
Received 1 Vote on 1 Post
Is it possible to check if the door lock of a washing machine is damage by connecting two wires in the connector?
I assume that the door lock has two functions: a switch that feels if the door is locked and a lock.
The door lock us Metalflex ZV-446 and it has 3 wires.
Thank you all.
Old 12-14-12, 02:02 AM
Received 1,348 Votes on 1,246 Posts
Your assumption on the operation of the switch is correct.
However, how to test it may be a little tricky. Since that is a non-US machine that it's used in I can't comment on its connections. I tried online searches and only found an incomplete schematic.
If you can post a pic of the wiring diagram for your machine I'll be glad to help you further. That diagram is usually somewhere inside the machine.......maybe on back cover.
Old 12-14-12, 06:37 PM
T
Wiring diagram
I couldn't find my machine diagram.
I searched and found a diagram of other machine that has the same door lock.
Is it helpful?
Thank you.
prashantom voted this post useful.
Old 12-14-12, 06:47 PM
Beautiful pic. Display looks like a car dashboard but unfortunately it's of no help to us.
We can see the door lock/switch and we can see the the three wires on it but they go to a power board. Without knowing the wiring on the power board I can't tell what wires do what.
I find a million mentions of that switch online but not a single pictorial diagram of it or its operation.
I'm still searching for an answer.
ON EDIT: In cruisng around I found this site. See if this helps you in your servicing. You never mentioned what the original problem was.
Hotpoint WMA50P Door Interlock & PCB - DIYnot.com - DIY and Home Improvement
Old 12-15-12, 01:23 AM
T
More Info
As for youe quwstion about the initial problem, the machine don't start ans the led above the start button is flashing.
As for the switch' it has 3 legs N, L, C as can be seen in the picture.
Old 12-15-12, 05:44 AM
pugsl's Avatar
Received 75 Votes on 68 Posts
The N is usually neutral but without a diagram can't tell what does what.
