Pugs PJ Kenmore washer fixed
Old 12-17-12, 02:19 PM
B
This morning started a load filled ok
started to agitate with no problem
went onto wash cycle for half of it
at that time the wife said it stopped ran in and dove for the motor plug in the dark low and be hold the red hot wire sparked and the washer started
observed the plug with it s little connectors and then noticed that the hot wire connector was spread out 50% more than the other connectors
squeezed the connector replaced the plug and fired washer up with no sparking at the hot wire, after 2 loads works like a charm
thanks to you both bob
Old 12-17-12, 02:39 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Most problems I have had is with neutral but could happen with any wire. Thanks good to know we helped.
Old 12-17-12, 06:54 PM
Received 3,602 Upvotes on 3,229 Posts
Good news ....Cheers back
