Access to bottom element in euromaid GFS60MSS oven.
The bottom element which is hidden under the ovenlining appears to have blown. How do I access this as it does mot appear ready accessable from inside the oven, unlike the other two elements.
Welcome to the site Dusty
I see you're from down under
This site is mostly US based members.
I couldn't find much info on your euromaid oven.
It can't be too much different from the units we have. The elements are usually made to be serviced from inside the oven.
There should be some type of removable pan in the bottom of the oven.
Sometimes it's held in with screws and other times it's a spring loaded clip system.
Thanks PJMax. I've checked again but it isn't that simple.
I was hoping someone could direct me towards a service manual. I can order the replacement element but have to wait until after New Year to get a service man to look at it.
Could start dismantling frm the front but I'm sure it is not that complicated.
Have a cold Xmas dinner anyway expected temp 39 celsius (102F)
Cheers
Cheers
You could stop down the appliance store and casually ask them how the bottom oven pan comes out.
Just googled your oven found pages about your oven but no service manuals. Just google model # and you will see what there.
