Freezer Drain Clog
Freezer Drain Clog
Do not know if this is correct FORUM but, here goes. My upright freezer drain continually clogs and of course of water cannot drain. I get out my blow drier and ice pick, remove ice and thaw the drain, I have been putting 1 OZ of household bleach down the line monthly and this works for a few months and then I repeat the thaw process. Is there a drill operated mini-snake out there that i can use to clean the drain hose periodically?
Is it the hose or the drain pipe that is clogging?
What shares the same pipework?
I can't see the water from the freezer clogging up the drain on it's own. Something else is causing you issues.
She is a upright freezer and the drain cavity is at base of defrost area, tray takes water to drain hole. from drain hole water goes vertically down to connect to a flexible tube that carries water to a tray under the freezer, I suspect constant blockage of the flexible tube, however I run bleach down the entire system monthly. I considered a piece of #12 copper wire hooked over the defrost device and run down the drain hole, but in my case the defrost device is GLASS and i an a bit antsy about hooking a piece of wire over the Glass tube (do not wish to fracture). I is a real PITA to go in and chip ice, defrost hole, snake a piece of string trimmer line length of tube every few months.
If you suspect the culprit is the flexible line I would replace it. You can get inexpensive vinyl tubing at most home centers. For a couple dollars you might take care of the problem or at least eliminate the tubing from the list of possible problems.
