Frigidaire oven (Model # FEF368GBA is no longer heating
Old 01-06-13, 06:35 PM
B
I was just using my oven when I checked on what I was cooking and noticed the oven had stopped heating. The stove top section works along with the broiler. Only when I select the "oven" option it does not heat.
Old 01-06-13, 11:23 PM
Received 3,884 Upvotes on 3,481 Posts
Welcome to the forum
I can see that's an electric oven but I can't tell how you set the oven temperature.
Is it a setting on a digital readout ?
or is it a knob with degree markings ?
It could be several parts causing your problem
The most likely and the easiest to test for is the oven heating element.
The second problem part could be the oven temp sensor if that's an electronic type oven.
The third part is the control module assembly
If you would like to troubleshoot this oven you will need a volt/ohmeter.
Do you have one and do you know how to use it ?
