Kitchen Aid Dishwasher with blinking light.
Received 0 Votes
We have a KitchenAid Dishwasher Model#KUDL02IR. The Start/Resume light is flashing
In the Troubleshooting section it states:
The dishwasher has malfunctioned Call for service to Check
heater circuit.
How can I fix it?
I have made sure that the door is sealing tight but nothing is happening and after a minute it clears everything and turns off.
Elise
heater circuit.
How can I fix it?
Elise
On your control panel, If you press these buttons in sequence then close the door it should reset the error code and you can run another cycle to see if it was a "once only" issue or if a problem still does exist.
{Hi-temp wash} - {heated dry} - {hi-temp wash} - {heated dry}...this should initiate a diagnostic/test program which will run for a couple of minutes.
See if that takes care of the problem or if it's still with us. If the problem remains then you'll need to check the heating element.
KUDL02IR Parts List
KUDL02IR Parts List
