Kenmore Ultra Wash Dishwasher Model 665-15819990
Old 02-10-13, 09:55 AM
G
Unit will not drain..I have checked the drain line at the machine and it isn't clogged. The unit works fine until it goes into the drain cycle then it cuts off and leaves water in the tub..I don't see a separate water pump so it must be included in the main motor..the unit is 12 yrs old and worked well up until this point..is it worth fixing or is it time for the dishwasher graveyard?..thanks in advance for any suggestions.
Old 02-10-13, 10:25 AM
Received 1,351 Votes on 1,249 Posts
Your machine has an integrated pump system. It could be as simple as a clogged filter or a damaged impeller. I've left you a link to the pictorial layout and parts list. Using the pictorial view below you're going to need to disassemble sump assy to determine the issue and then order parts. You may also want to check valve.....part # 15 .....located in drain line for a clog.
After clicking on link...... click on "view full size" under small pic. The pic will now open in a new window. Click on that new pic and it will be a large view that you can move around with your cursor.
http://www.searspartsdirect.com/part...&prst=&shdMod=
The following link is from a different site. Shows you the rebuild kit and they have a video to show you what is involved in the process.
Whirlpool 675806 - Drain and Wash Impeller Kit | PartSelect
