Maytag top washer PAVT920AWW
Old 02-11-13, 12:31 AM
H
Exclamation Maytag top washer PAVT920AWW
Hello, I des patently need help with my washer. I have a newborn so I'm in need of a washer that works. My washer fills up with water fine and in the first cycle it will rotate fine. After that the spin will not spin at all and the water will not drain. It will spin and the belt spins at first but the second and final spin it just makes a big noise like its spinning but it's not and the belt doesn't move either. Please help, I need the cheapest way to fix it as newborns are already expensive so I am not able to purchase a new set. Thanks ahead of time
Old 02-11-13, 05:39 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Lean washer back against wall and take belt off, Water pump is back right conner try to trun pulley, Should turn freely and no noise. Let us know what happens.
