Trying to fix a dryer that doesn't get hot.
Old 02-22-13, 04:12 PM
E
My dryer doesn't get hot. I feel like I have trouble-shot the common problems:
1) Reset circuit breaker
2) Checked for proper air flow
3) Tested element with multi-meter, works fine
4) Tested thermostat and thermal cutoff, replaced both
5) Switched the leads to the element to see if I was inverted
My dryer runs just fine but doesn't heat. Does anyone have any other ideas?
Old 02-22-13, 05:07 PM
pugsl's Avatar
Received 75 Votes on 68 Posts
Post model # and type of dryer. Does it heat at all ?
Old 02-22-13, 07:17 PM
E
Kenmore
Model/Stock
96589210 65892
Its an electric 240V dryer. The element is accessed through the front.
It doesn't get hot at all unfortunately.
Old 02-22-13, 09:37 PM
pugsl's Avatar
Model # did not work, Should be a tag in door opening and will start with a 110. Usual problems with your dryer is either a open heater element or thermostat. Should have continuity between 2 wires at heater. Front wires at heater, Look toward back you will see 2 thermostats mounted on heater box the one in back is the high limit one and it should have continuity. If either is open that is the bad part. Both thermostats and heater should not be open. Let me know what you find. se that you replaced thermostats but which ones?
Old 02-23-13, 03:48 AM
Received 1,335 Votes on 1,234 Posts
Did you actually measure 240 vac inside the dryer. The heating element runs on 240 volts. The rest of the dryer runs on 120 vac.
Old 02-23-13, 04:02 PM
E
I didn't measure the voltage inside the dryer, I was just referencing that to give information about the dryer model.
The tag inside the door says Model/Stock 110.96589210 then it has several spaces and then says 65892. The serial number is MF2040333 if that helps.
Here is a picture of the two thermal cutoff pieces I replaced.
http://www.rcappliancepartsimages.co...9-00699522.jpg
They are the pieces that were attached to the element housing. The one that is on the right in the picture is the one that failed the continuity test, but it was only sold as a package at my local Sears parts center so I replaced both.
Old 02-23-13, 06:06 PM
E
Thank you everybody for your responses. My roommate looked at my "fix" and diagnosed my incorrect installation almost immediately. I am back in action!
Thank you again for spending your time and energy on my problem.
Old 02-24-13, 02:40 AM
Thanks for the update
