AED4475TQ1 Admiral Dryer only runs when the start button is pressed.
Received 0 Votes
AED4475TQ1 Admiral Dryer only runs when the start button is pressed. I just replaced the timer because of another problem and it worked great for a couple of days. It doesn't seem to be heating.
We're back to the motor wiring. We were there not long ago.
When you push the start button....the motor starts spinning and one of the centrifugal switches on it keeps the dryer running.
Your dryer may use a start relay, If it did it would be shown on the wiring diagram that is attached to that machine.
You will need to check all the wiring on that plug. The part number below may be the replacement switch for your motor. I couldn't tell without seeing the motor in your unit.
WE4X344 is a replacement starting switch assembly.
W10194250 is a replacement motor
Different problem from the not running other post. Doesn't seem to heat? does it heat at all?run dryer a couple of minutes and see if warm inside, May have different problems with what you find. Dryer does run now?
