Do Chest freezers have a defrost cycle?
Received 0 Votes
Just wondering if chest freezers (basement type, no fridge section)have a defrost cycle like a refrigerator?
Do they use a timer/defrost switch & heating element to defrost the evaporator coils like a fridge?
No.....most, if not all, chest freezers do not use a defrost system.
The reason they don't use a defrost system is because the constant unthawing will reduce the storage life of the food. A chest freezer is good for long term frozen storage.
I recommend that the unit be turned off, unthawed and cleaned once a year to keep running efficiently. Of course if it gets iced up it will need to be done sooner.
Received 0 Votes
Thanks PJ,
Appreciate the quick reply
One more quick question, how do they keep the evaporator coils from icing up?
Do they not ice up because a deep freeze cycles far less than a fridge?
They have a defrost system in a refrigerator/freezer combo because they expect the doors to be opened many times letting in warm humid air.
In a storage freezer the door most be opened as little as possible. If the door to an ice chest is left open.....you will get a giant block of ice in the bottom.
In most chest freezers I've seen, the evaporator tubing is bonded to the metal inner liner shell of the freezer, and indeed does frost/ice up. Chest freezers do not use a separate evaporator/fan assembly as do refrigerators and frost-free upright freezers.
Just a general side note here....don't buy a frost-free upright freezer if you want good, long term storage. The defrost cycle will partially unthaw food resulting in much shorter storage time.
