washer fills then completely stops, when I turn knob washer spins
Old 06-30-13, 01:31 PM
Washer fills with water normally, but then washer completely stops. If I turn the timer knob forward, spin will start and cycle will complete normally. I cannot get it to agitate at all. I replaced the timer switch but it did not fix the problem. Lid switch seems to be working ok. This is a Kenmore 98702 Stacked washer/dryer. Thanks for your help.
Old 06-30-13, 01:40 PM
Received 410 Votes on 385 Posts
Welcome to the forums.
I need the full model number for your unit. It may be 417. xxxxxxxxxx for a Frigidaire built unit.
Check again for the entire part number.
Old 06-30-13, 01:41 PM
Maybe I should mention that the timer is not progressing on its own. If I don't move the timer forward, the spin cycle will never start on its own.
Old 06-30-13, 02:00 PM
model number
I was mistaken, the model number is 94702. Does this help? I can't seem to find a number in the format you mentioned.
Old 06-30-13, 03:50 PM
Still the wrong number, with what you posted all you'll get is generic guesses.
Old 06-30-13, 03:52 PM
pugsl's Avatar
Received 25 Votes on 24 Posts
I think this is your model # 41798702890 Look inside door of dryer and check. It sounds like the timer , did you replace with a new timer?
Old 06-30-13, 04:03 PM
The model number for your machine is 417.94702300
Take a Sharpie marker and write it on the back of the machine.
Timer switch ?? Or did you replace the timer ?
A defective lid switch or a defective fill pressure switch will cause your problem.
A link to service info from Sears. Your service info actually has a wiring diagram listed
Sears parts direct /Kenmore/Washer-dryer-combo-/Model-41794702300
Old 06-30-13, 05:45 PM
Thanks guys. I did replace the timer switch. Also, while it is draining, the pump turns off and on when I open and close the lid. Would that eliminate the door switch as a problem?
