Ice Maker
Old 07-20-13, 08:20 AM
mr_sma_jr's Avatar
Ice Maker
I replaced my ice maker, in the side by side refrig but it doesn't seem to work... The last one did but just leaked... 3 screw, 1 4-pin connector... ???
Old 07-20-13, 08:26 AM
Received 3,490 Upvotes on 3,133 Posts
Did you replace it with an ice maker from the same manufacturer as the fridge or did you purchase an aftermarket ice maker ?
It's very rare to have wiring issues with the ice maker. Usually the only problem you'll have is that the plug is not wired the same way or the water fill valve is defective.
Old 07-20-13, 08:28 AM
mr_sma_jr's Avatar
Same model -everything...
Old 07-20-13, 08:45 AM
Has the unit been in and on at least 24 hours ?
You don't have the metal arm up that shuts the ice maker down when bin is full..... do you ?
Sometimes by raising and lowering the arm several times will start the unit.
Try reaching in and see if there is ice in the tray.
Old 07-20-13, 08:55 AM
mr_sma_jr's Avatar
No 2 hours, in & out 3 times... No water in the cups... Same wiring, tried swapping our the control on the good with the bad - same results... Should water flow at power on ??? or doe it need 24 hours also ??? The bad unit was making ice this morning
Old 07-20-13, 08:59 AM
No.....water doesn't flow at turn on.
The ice tray must completely reach below 10 degrees and then unit will go into a harvest cycle. At the end of the harvest cycle comes the water fill up.
Old 07-20-13, 09:03 AM
mr_sma_jr's Avatar
roger that - I will wait... had it in/out so many time, I think I can do it in my sleep...
Thank you
Old 07-20-13, 09:34 AM
mr_sma_jr's Avatar
water just filled - all looks good - Thanks again
Old 07-20-13, 09:59 AM
Ice cubes ........... here we come You're welcome
