Kenmore dishwasher not draining
Old 10-13-13, 02:27 PM
C
I have a Kenmore dishwasher (model: 15705891) that will not drain. I know absolutely nothing of household appliances but decided to take off the drain hose and see what would happen. I ran another cycle and the dishwasher started draining into a bowl fine. The hose doesnt appear to be clogged either as I was able to spray water through. Is it possibly a pump that is gone out ? I would have thought it wouldnt drain at all without a pump working though..but what do I know...Thank you in advance for any advice!
Old 10-13-13, 03:24 PM
Old 10-13-13, 04:49 PM
Received 1,182 Votes on 1,095 Posts
Welcome to the forums.
Do you have the dishwasher connected to a garbage disposer or directly to the drain ?
If it drains fine not connected then possibly where it's connected to is plugged.
When you dishwasher is supposed to be draining do you hear the pump running ?
There is a check valve in your drain line that could be causing your problem.
In the links is a video that shows you how to remove the check valve and replace it. At that point you can check it for clogs.
http://www.youtube.com/watch?feature=player_embedded&v=hgvXVGPJqLM
