Whirlpool Gold - freezer not freezing - fan not running
Old 11-24-13, 12:59 PM
Hello experts
My Whirlpool Gold model gs2shexnb00 is no longer freezing. I pulled the coil cover and notice the fan is not running - it is cold but not cold enough.
The refrigerator side is working fine - only the freezer is the problem.
In searching for a fix, I have found the likely fix to be the run capacitor - my question is does this only effect the freezer section??? I don't thing so, so what else may be causing the fan to not run? A control board maybe...
Thanks in advance
Mark
Old 11-24-13, 02:42 PM
UPDATE
I cycled all power and turned up the house heat - the fan is now running
Is it possible that the ambient temperature can effect the cooling?
Old 11-24-13, 05:18 PM
Received 4,153 Upvotes on 3,730 Posts
Welcome to the forums.
Which fan is not running..... the condensor fan under the fridge or the evaporator fan inside the freezer ?
