Kenmore side by side
Hi All, I have a Kenmore 10658432700 side by side and the freezer is running about 12 degrees compressor is running Tstat is set on 5 ,any thoughts?
Thanks
Thanks
Is the compressor running continuously ?
Have you vacuumed out the condensor coils under the fridge recently ? They coils and fan should be cleaned once a year in a kitchen application.
You may also have a defrost issue. Can you see the coil in the freezer and is it iced up ?
Coils have been vacuumed recently,not sure where I would find the coil,is there a separate fan for the freezer? What temp should I expect to see in the freezer, and refridge?
Thanks
Thanks
