Kenmore Dryer Model 417.84052500 makes loud noise when started cold
Old 12-15-13, 10:21 AM
F
Hi,
My Kenmore dryer model 417.84052500 makes a loud grumbling noise when I start it cold. The noise lasts for about a minute, then stops. Otherwise the dryer works fine.
I replaced both the belt and the bearing assembly to no effect (now I hear an intermittent rattling noise when I run it).
Any advice would be appreciated.
franks999
Old 12-15-13, 11:47 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Are you saying it makes a humming sound and than ti starts? If it does usually the motor is going bad.
Old 12-16-13, 08:37 PM
F
Hi-
Thanks for your response. It makes the humming sound after it starts. It's pretty loud for about a minute, then sounds almost normal (there's still the rattle/vibration sound).
Old 12-17-13, 02:58 AM
pugsl's Avatar
After it starts or before (before usually motor) After I have never heard it. Rattle sound could be blower wheel loose on shaft and will need to be replaced.
