Ge gss25tgpa ww not working
Hi I have a problem with the same fridge. The compressor is not working I check the entire fridge and realise I am not getting power off one of the pins on the board. Do you think I might have to change board?
I had same issue and fixed yesterday.
Here is the thread: http://www.doityourself.com/forum/el...d-cooling.html
Welcome to the forums.
Mystery is now our new authority on GE side by sides.
I'm guessing you posted in that thread and your post was moved to its own thread.
Your fridge is not exactly the same but the compressor and control board are similar and can be diagnosed the same way.
If you aren't handy with a soldering iron..... you might have to replace the control board.
Have you definitely confirmed that you do not have 120vac to the compressor ?
Is the condensor fan under the fridge running ?
In the link below is the parts breakdown for your unit. Pictorial 801 is the control board.
The link is for illustration purposes as there are other places to purchase the board from.
Sears parts direct/GE-Refrigerator-Parts/Model-GSS25QGTAWW
Pete
Pete
