Kenmore 80 washer tubs fills...that is all
Old 01-04-14, 12:47 PM
The tub on my Kenmore 80 series washer fills but I get no agitation, spin, or draining. Could it be the lid switch is defective? I accessed the switch and housing appears to be intact and not broken. The switch makes a "click" sound when paddle is depressed. I don't have a continuity tester so don't know for sure if its bad.
Marvin
Old 01-04-14, 12:53 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
post model # can help better. Don't think lid switch usually will agitate if bad. Possible white wire that goes to motor is not making connection and will cause your problem.Lean washer back against wall and wiggle wires it may start.
