Maytag washer won't spin, but does everything else.
Old 01-11-14, 06:11 PM
O
Hi, my Maytag Atlantis model #MAV6200AWQ will agitate, drain, but won't spin. The washer makes the noise of it spinning and I even feel it move like it's spinning. But, it the tub doesn't move. I bought it in 2002 and replaced the transmission in 2008. Any thoughts and advise would be much appreciated!!! Thanks so much!
Sherrie
Dalton, GA
Old 01-11-14, 09:06 PM
O
Thank you. Wish I knew exactly what it needs.
Old 01-12-14, 05:15 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Dose it make any noise when in spin? If no let us know. If no noise don't do following.
lean washer back against wall so you can look under it. Check belt is good and the water pump turns freely. water pulley front right corner. Take belt off to check, Leave belt off and turn center pulley both directions , One way will turn agitator the other way will cause the transmission to lift and will turn basket to spin.
Old 01-12-14, 07:30 AM
F
He said "The washer makes the noise of it spinning and I even feel it move like it's spinning". Check to see if it's agitating instead of spinning. If so, you have a bad transmission. Common on these washers.
Old 01-12-14, 03:08 PM
O
Hey, it agitates when it washes, but when it comes to the spin cycle, nothing happens. No agitation or spinning.
Old 01-12-14, 03:12 PM
O
Thanks, it does make noise when it spins. It sounds like it's spinning, but the tub doesn't move at all.
Old 01-13-14, 02:40 AM
pugsl's Avatar
Most likely you will need a transmission.
Old 01-13-14, 01:52 PM
O
I should have added that before it tore up, there was a shirt wrapped around it so tight, I had to cut it out. Also, the tub won't move at all, not even when I try to turn it.
Old 06-25-14, 05:10 PM
O
Update: I had a new transmission put in it, and it STILL doesn't spin!!!! The man that put the transmission in is stumped. Any advise would be appreciated. Thanks!
Old 06-26-14, 04:09 AM
pugsl's Avatar
Did he replace the thrust bearing kit when transmission replaced? If not did he lube the ramp part in plastic part? Take front off and lean washer back against wall, take belt off and turn center pulley both ways. One direction you should see transmission lift a little. The lift takes it off the brake so it can spin.
here is a diagram of transmission. part # 24 is bearing kit
MAYTAG Washer Transmission Parts | Model MAV6200AWQ | SearsPartsDirect
Old 06-26-14, 06:30 AM
F
Rotate center pulley CCW for spin. This should cause the pulley to lift a little which lifts the brake rotor that is inside the brake housing. It does not lift the transmission. After the brake is released, continuing to rotate the pulley should cause the entire transmission to rotate.
