Maytag Electric Range won't maintain heat
Old 04-25-14, 09:06 AM
E
I have a Maytag MER8674 Electric Range that's 18 months old. It will start to heat up to a desired temp then won't maintain the heat even though the display says otherwise. It didn't get hotter than 200 degrees then I replaced the oven sensor. Now it heats to, say 350, but shortly there-after doesn't maintain the 350 temp, seems more like 100 degrees. The lower heating coil looks in tact and isn't pitted. Any ideas?
THANKS in Advance!
Old 04-27-14, 08:16 PM
Received 1,104 Votes on 1,024 Posts
You've only left me a partial model number.
My hunch is a defective control board. A bad relay or poor solder, in particular.
Old 04-28-14, 06:41 AM
E
The only part left of the model number is B for Black range. How do I troubleshoot which one it is?
Old 04-28-14, 08:25 AM
MER8674B is not a valid model number.
Old 08-28-14, 06:47 AM
E
The full Model number is MER8674AB 0
Any ideas what to check for first? The oven does heat but does not hold the heat and typically not up to 375 degrees.
TIA!
