Whirlpool DW delay light blinking
Old 05-24-14, 12:51 PM
W
I have a whirlpool Gold Quiet Partner III MDL# GU1200XTKQ0 SN# FL2308257. The issue is that the delay 4 hour light is blinking. I replaced the Control Board (after a lengthy discussion of my previous troubleshooting steps with parts store tech) and flipped the breaker and it looked to be fine. A couple of minutes later I walked by and the delay 4 hour light was blinking again. So I opened the door and left open for a few minutes then closed it back. The delay lights went through a 2-4-8 sequence about 6 or eight times, the refill rinse aid light came on went off and finally stopping on the 4 hours blinking. Thoughts?
V
Old 05-24-14, 03:16 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
This is a problem that I haven't seen before.
I'm looking for a diagnostics routine for your appliance.
Just some things I've found.........
To cancel the delay and start the cycle, press Delay Hours until 8 glows. Then press Delay Hours one more time. The delay turns off and the delayed cycle starts.
Try pushing the sanirinse button - dry button - sanirinse button - dry button
That may reset the processor or put it into a diagnostic routine.
I haven't located a tech sheet yet.
Old 05-24-14, 04:39 PM
W
I tired the "sanirinse button - dry button - sanirinse button - dry button" and all that did what make the "normal" light blink in addition to/with the 4 hour light. I hit cancel and nothing happens. I open the door/close the door and the "fill rinse" light and 2 hour come then it moves to 4 hour and then "fill rinse" goes off and 4 hour starts blinking. Also if I hit any button other than "cancel" (which does nothing) the "normal" light starts blinking with the 4 hours light. I just think it is possessed.. ha...
Thanks for your help so far...
V
Old 05-24-14, 04:57 PM
I'm still looking. So far I haven't found anything that addresses your problem.
Old 05-26-14, 09:49 PM
W
Think I found the problem. I found instructions on how to test a touchpad for a Whirlpool and have a stuck/open "normal" button.
Thanks for your help!!
V
Old 05-26-14, 09:59 PM
Thanks for letting me know what you found. It will help others in the future.
