water inside Frigidaire Refrigerator
Old 05-25-14, 03:26 AM
I keep finding water in the bottom part. It's a top mount freezer, with an built in ice maker. but the ice maker is not, hooked up. so I know it's not a water line. But, I can't find were the waters coming from: confused: anyone got any ideals.
Old 05-25-14, 04:52 AM
P
Received 620 Votes on 573 Posts
Check the drain pan and line that's underneath the coils in the back of the freezer. When it goes into defrost mode the ice melts off the coils, gets caught by the catch pan then into the drain tube that carries the water to a pan underneath the fridge where it evaporates. If the drain hole in the pan is plugged, drain tube plugged or if any of the fittings have come loose the water can leak out.
You'll need to remove everything from the freezer then remove the back panel. Then you can see the coil and it's catch pan. If the problem is not immediately obvious you can pour a little water in the pan and look for it leaking into the fridge section.
