Frigidaire Washer knocks during spin cycle
Old 06-02-14, 12:52 PM
E
So, I have a Frigidaire washer that makes knocking sound when the spin cycle gets up to full speed. The interesting thing is that when I took the protective cover off the top of the washing drum the spin cycle proceeds with no problems at all.
Any ideas?
Old 06-02-14, 01:26 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Please post model# and is it a top or front loader.
Old 06-02-14, 03:32 PM
E
Ah, thank you.
The washer is a top loader. Frigidaire model # GLWS1649AS1
Hope this helps, I still have no idea why having the cover off gets rid of the knocking sound. Nothing is stuck between the inner rotating drum and the outside drum.
Old 06-02-14, 03:49 PM
pugsl's Avatar
Cover off? What cover are you talking about. Here is diagram of washer
http://www.searspartsdirect.com/part...od=GLWS1649AS1
Have you taken the front off and looked in there? Where does the noise come from top, bottom sides?
Old 06-02-14, 05:28 PM
E
Thanks for the parts link. The piece is the Cover Splash. Part # 131551102.
I currently have the top up and the front off of the machine. The sound is coming from the Tub area.
Old 06-02-14, 08:05 PM
E
Issue has been resolved. I pulled out the inner washing drum and discovered that the circular filter underneath had come loose. Once it was secured back in place all was well. I can only assume that taking the cover splash off released some tension and let the filter simply sit in place.
But all is well and the unit is running a load as I type this.
Old 06-03-14, 01:07 AM
pugsl's Avatar
Thanks for the update. Not a common problem and only way to find it was look.
