Go Back  DoItYourself.com Community Forums > Household Cleaning, Kitchen Appliance Service and Repairs > >Electric< Large Kitchen and Home Appliances
Reload this Page >
Fisher & Paykel GWL15 washer drain pump test -- is the pump bad? (with video)
Old 06-06-14, 08:04 PM
I
Last time I ran my Fisher & Paykel GWL15 washer it failed to drain. Dug up their service summary instructions and performed the drain pump test in the diagnostic mode. The result can be (sort of) seen in this short video. "Sort of" because I did not turn the camera right after I hit the REGULAR button on the washer to run the test. What you cannot see in this clip is that at the very beginning the wheel did turn about 1/4 of a circle. In the video you can see it's no moving. Plus water is dripping from I think inside of it.
A few months ago I followed the advice of this 3 part video (part1, part2, part3) to get rid of the awful screeching noise it was making. Except I treated the pump with WD40 instead of the lithium grease this guy used. It worked, then about a month ago the machine started to make a little bit of noise, then this happened yesterday.
Does this look and sound like the pump needs to be replaced? Or maybe fixed? Or something else wrong? Thanks!
Old 06-07-14, 03:47 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
You got about 6 years longer than I think washer good for, Hate that machine. Forgot how to open washer but best way to tell if pump is to get to it and run it with noise. unplug pump, usually would say while running but you are right board are a common problem and can blow with sudden loads. Stop washer and try again. You might be able to feel a roughtness when pump is running if you put your hand on it. Yes it dose sound like pump. If you turn drain off does the sound stop?
