How old is this thing - MARKEL HEAT AIR
Old 06-13-14, 12:06 PM
Received 1 Vote on 1 Post
In one of the bathrooms is this very old heater.
It still works, it's on a 120V 20A circuit. When I flipped it on I can feel heat coming out with a bunch of clicking sounds.
Reading the labels closely I can see:
MARXEL ELECTRIC HEAT AIR
CAT. NO. 241-NA
VOLTS 120
WATTS 1000
CYCLES <- this one is unreadable
MARXEL ELECTRIC PRODUCTS INC.
I looked this up this company is no longer around.
The previous owner had put in new tiles but didn't remove it but tiled around it. I don't know how old this thing is and whether it may explode one day. May be I should disconnect it at the panel? I don't think we need a bathroom heater in Miami anyways not even during the winter.
Old 06-13-14, 02:31 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
How old is the house? Most likely installed when house built.
Old 06-13-14, 03:44 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Unlikely at only 120 volts. Usually takes a dead short on 480v or higher to get a really could explosion. It would probably just trip the breaker with maybe a little pop.
Old 06-13-14, 06:05 PM
Received 1,109 Votes on 1,029 Posts
I corrected the title. The name of the company is Markel.
Old 06-13-14, 06:58 PM
pugsl's Avatar
Found this don't know if it helps
Markel Mechanical Distribution Products - Main
Old 12-04-14, 06:45 PM
It's on a dedicated 20A circuit.
It's drawing 1000W, I am wondering if I can just pigtail it with the bathroom circuit which currently powers a sconce (3 X 40W bulbs) and a GFCI receptacle which most times it's for charging a electric razor or using a hair blow dryer.
If I can free up that circuit I can re-purpose it for an exhaust fan for that bathroom.
Old 12-04-14, 08:12 PM
ray2047's Avatar
Current code requires a dedicated circuit for bathroom circuits. If that circuit serves only one bathroom the lights can also be on that circuit. The exhaust fan/light uses very little current and can be on the bath dedicated circuit. The heater however uses far more current and should be on a dedicated circuit.
Old 12-05-14, 06:49 PM
Right now I have two circuits going to the bathroom. They are a MWBC and share a common neutral, both circuits on opposite legs on double pole breakers.
One circuit goes to the bath heater which is probably never going to be used, it's old, and we are in South Florida.
The other circuit goes to the bath and it powers the wall sconce (3X40W) and a GFCI receptacle.
I am thinking of adding a bath exhaust fan in the bath ceiling.
My options are:
(1) Disconnect the heater altogether...and connect the exhaust fan to that circuit instead.
(2) Put the heater on the bath circuit, so the exhaust fan can have it's own dedicated circuit.
(3) Put the exhaust fan on the bath circuit. and leave the bath heater alone.
Option 3 is the way to go?
