GE French Door/ lower freezer-gfss6kkyss- fridge side not staying cold
Old 06-20-14, 01:48 AM
C
I have a GE French Door/ lower freezer model gfss6kkyss fridge. Problem is that the fridge side does not get colder that 49 degrees. I tried almost everything. Changed the motor in the fridge compartment & made sure the fans in the freezer side works. Manually defrosted the inside fridge & heater with a blow driver.
I had this fridge for 5yrs. I checked the digital temp control. Nothing seems to work. Please help
Old 06-21-14, 01:14 AM
Received 1,105 Votes on 1,025 Posts
Welcome to the forums.
Why did you change the fan motor(s)..... were they bad ?
Was the inside coil iced up ?
Have you cleaned and vacuumed the coils and the fan under the fridge ?
