Bosch SHE3AR55UC/08 Not draining
Old 06-20-14, 07:25 PM
Hi,
I have a Bosch SHE3AR55UC/08 dishwasher that doesn't always drain at the end of the cycle. When I open the door, there is standing water above the filter.
However, if I close the door, run a cycle again, but this time quickly cancel out, I hear the vibe pump kick in and when it finally finishes from the cancelled cycle, the water is gone.
So it's clearly not clogged..
Any ideas ?
Thanks !
Old 06-20-14, 10:34 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
Have you removed the cover over the filter to see if it's clean below there ?
Another common drain problem is the drain line is not run high enough to the drain. See the illustration below.
Old 06-21-14, 03:37 AM
Hi
Thanks for the reply.
The machine is capable of draining. I do not believe something is preventing it from draining.
The reason I say this, is because if I run the cycle again and abort it, the water that was remaining from the previous cycle is now drained.
Thanks
Old 06-21-14, 01:00 PM
If your certain everything mechanical is ok......then that leaves the control board as suspect.
Old 06-21-14, 05:32 PM
That was my thinking as well.. I hope we are both wrong because I can't seem to find a controller board anywhere. They better not be discontinued.
I will try using a different cycle from Auto and see if that helps.
Thanks again for the reply. I appreciate it.
