Replace cylindrical igniter with flat igniter cause problem?
Old 07-04-14, 11:40 AM
P
Have an OLD Caloric RWP212 gas built in oven that used a cylindrical igniter that has gone bad. Cannot find a cylindrical replacement part (0206RC04 T). Will it be possible to use a flat igniter for this relic? Will it require getting a new gas valve holder to attach?
This is my first time using this sight, so unsure what to do next!
Old 07-04-14, 12:01 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
Using the model number of your range it looks like you should be using a flat igniter.
Caloric Range/Stove/Oven Model RWP-212 (RWP212) Igniter Parts from Repair Clinic
Is this parts listing incorrect for your stove ?
I couldn't find any listing on the part number you supplied so I'm curious where you obtained that from ?
Old 07-04-14, 12:08 PM
P
I have the part in my hand! It's my understanding that it's the original part. The part number I got from what is written on the part itself. Also has the number 9306 on the cylinder.
Old 07-04-14, 12:12 PM
P
the part also has the words CARBO on the cylinder. The owner says it may be the original oven that was there when he moved there in 1964.
Old 07-04-14, 12:35 PM
Check out the link below. Let me know if that is what yours looks like. The bracket may be slightly different.
Round Universal Silicon Carbide Hot Surface Furnace Igniter/Ignitor - Replacement Household Furnace Ignitors - Amazon.com
9306 is a date code. 1993 would be the year that was manufactured. So it may be a replacement.
Old 07-04-14, 12:46 PM
P
Yes! the bracket is different, but I can feed the wires through an additional ceramic tube and metal cover that holds the bracket I have which is reusable.
Old 07-04-14, 01:16 PM
P
I see that this Universal silicon igniter is no longer available. Should I go with just any Universal round carbide hot surface igniter?
Old 07-04-14, 01:49 PM
FYI..... Carbo is short for Carborundum. I've found several older numbers that work in Caloric ovens. I'm trying to find out what the difference is between them .
Although that style is similar to yours...... the igniter in the picture was used in a furnace. They don't all run on the same voltage.
Old 07-07-14, 09:07 AM
P
Update?
Hey PJmax, do you have update on the voltage comparisons on the igniters? I'd like to order one soon. Thanks for all your help
Old 07-07-14, 11:29 PM
I would check directly with the following company.....
Appliance Parts Unlimited - Caloric gas stove oven igniter
