Whirlpool Duet washer doesn't spin clothes out very well
Old 07-18-14, 01:25 PM
I have a Whirlpool Duet WFW9150WW02 washer that ends with dripping wet clothes. It seems to go through all the cycles fine. It seems like it needs to be spinning faster on the spin cycle though.
Any ideas? Also, can anyone direct me to the repair manual for this washer? I need to get into troubleshooting mode to see what error codes there are.
Thanks everyone.
Old 07-18-14, 02:20 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Take lower panel off and tech sheet should be in panel or taped to side. Your washer does not store codes if no code showing than usually no code. Most common reason for wet clothes is wrong soap or pump coin trap need cleaning.If you open coin trap there will be up to a gallon of water there if washer drained.
Are you using HE soap and about 1/2 of amount listed?
Old 07-21-14, 05:01 AM
The resident claims to use a small amount of soap. I ran a towel through a cycle without soap, and during the rinse cycle there seemed to be some bubbles. Could this be air bubbles from the agitation, or leftover soap from previous loads?
Also should it spin very fast on spin cycle? Or is it normal for the front loaders to go slower than a top loader would. It seems spin awfully slow to me.
Old 07-21-14, 08:19 AM
pugsl's Avatar
Should go fast on spin cycle. Are any codes there? Tech sheet will tell you how to get into diagnostics. Samll amount of suds usually ok but if quite a bit not.
