Maytag Dishwasher wont complete cycle
Old 07-27-14, 10:07 PM
N
It gets a few minutes into the cycle and will stop. the tough scrub light plashes and there is usullly a little water in the bottom of the washer i can hit the cancel drain button and it will drain but if i push any other button it just flashes.
Any help is appreciated.
Model # is MDB6769AWB1
Old 07-28-14, 01:17 AM
Received 3,609 Upvotes on 3,235 Posts
The flashing scrub light on this model means that the touch pad has detected an internal short in the touch pad itself.
It may have gotten wet. Try turning power off to the dishwasher for 24 hours to see if drying it out fixed it.
Old 07-28-14, 01:42 AM
N
Thanks for the reply i let it set over the weekend but its still doin it
Old 07-28-14, 03:57 PM
N
I was quoted 170 for the main circuit board with a 30 dollar core charge if i bring the other board in. Does this seam like a reasonable price? Also is this what i need i talked to a parts store and he said main circuit board (not sure how many circuits there are), and if anyone has the part number i would appreciate it!
Old 07-28-14, 04:28 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
not sure if this is what you need W10285180 Here is a site to find your parts
MAYTAG Undercounter Dishwasher Parts | Model MDB6769AWB1 | SearsPartsDirect
Old 07-29-14, 11:14 AM
N
Thanks for the link are there any special tools i need?
Old 07-29-14, 04:26 PM
N
How do i remove the strip from the circuit?
Also can anyone tell me if there is a certain part on the board that is getting moist or is it just random
Old 07-29-14, 05:49 PM
pugsl's Avatar
The plastic strip will pull out of black block or the black block will pull off pins. Usually strip will pull out of black block. Be genital.
Old 07-29-14, 06:30 PM
N
thanks! is there an area where i should be checking on the circuit board for any abnormalities to see which part got wet
Old 07-29-14, 11:03 PM
That was in my post. The touch pad..... not the control board. Although since the problem can occur on either board be sure you purchase it from a parts retailer that will take it back if it's not the problem. Water can get in the keypad, the connecting ribbon cable and the connecting plug on the control board.
Maytag Dishwasher Touchpad and Control Panel W10254841 Order now for same day shipping. 365 day return policy. Repair Clinic
Old 07-30-14, 05:22 AM
pugsl's Avatar
That is why I said to check part. Was not sure control board was seperate from user interface. Ribbon cable goes to interface. I had one I took apart and put paper between what was touching and was able to get it working but only had 1 cycle. Not sure yours would do that.
