Dryer: 4 prong to 3 prong conversion problem
Old 08-16-14, 03:13 PM
C
Received 6 Votes on 5 Posts
Hi- I'm installing a dryer that had a 4 prong plug. There are only 2 poles on the wiring block in the back. The pole on the left has a strap that connects to a nut below the wiring block. The wires were connected like this:
- white wire to pole on the left
- black wire to pole on the right
- green to a ground nut on the back of the cabinet
- red to a blue wire in the back of the dryer
Using a flat 3-wire plug I connected the wires like this:
- middle to the ground nut on the cabinet
- outside wire to the left hand pole on the wiring block
- other outside wire to the right hand pole
When I jack the 3-prong plug into the wall, there's a spark and the breaker trips. What have I done wrong?
Tried to upload a photo and couldn't, sorry.
Thanks for any help!
Old 08-16-14, 03:19 PM
Received 1,113 Votes on 1,033 Posts
It sounds like one of the terminals was burned and no longer used.
A picture is going to be needed to help you.
http://www.doityourself.com/forum/el...-pictures.html
Old 08-16-14, 03:24 PM
C
Photo that I couldn't load previously.
The blue wire I mentioned above is the one with the wire nut on it now.
Old 08-16-14, 03:30 PM
That terminal block is missing the third terminal and will need to be replaced.
Old 08-16-14, 03:31 PM
C
More info now that I'm thinking about it further:
There's a strap connecting the white pole to the sheetmetal bracket that supports the wiring block: shown as the nut just to the right of the white vertical wire in the photo. In the 4 wire install, the ground nut also connects to that bracket. I used that same nut as ground in the 3 wire install. That must have created the over current that trips the breaker.
Old 08-16-14, 03:49 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You have two hot wires a neutral and a ground. Where are you connecting the two hot wires. As PJ said you are missing one of the two terminals for the second hot wire.
Old 08-16-14, 03:52 PM
C
I just noticed the bakelite (or whatever it is these days) is broken off.
Old 08-16-14, 03:55 PM
ray2047's Avatar
Yes that is what we have been saying.Here is a 3-wire connection:
Old 08-16-14, 04:27 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Give a make and model # and we can find a replacement part #
