Dishwasher drain
Old 08-30-14, 08:48 AM
R
Dishwasher drain
My dishwasher drain line going to the garbage disposal is long and has a loop in it. The tube starts out low at the dishwasher and rise up about a foot and a half to where it goes into the garbage disposal. The wife says she smells something coming from the kitchen drain and she possible sees something in the tube close to where it loops. The dishwasher was installed by company where I bought it and works fine but now it smells and has water on the bottom tray sometimes. Any idea of the possible problem.
Thanks
Old 08-30-14, 09:08 AM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
The loop needs to be higher... ( Note: Some newer dishwashers have the loop built into the side of the dishwasher already)
[ATTACH=CONFIG]37387[/ATTACH]
Old 08-30-14, 09:30 AM
R
The loop is on the floor of the cabinet not anywhere close to the diagram. The service man is coming out to look at it due to it still being under warranty. I take it that the dishwasher will push the water enough to go up to loop and then to drain.
Old 08-30-14, 10:07 AM
Received 1,202 Votes on 1,112 Posts
Yes....the dishwasher has plenty of power to push the water up thru the drain line even with it fastened up high.
If you have the installation booklet that came with the washer it should show that drain hose attachment or make mention of a vacuum break.
Old 08-30-14, 11:35 AM
Handyone's Avatar
This question comes up a lot.
A high loop may be fine in some areas. In CA, an Air Gap is required by code.
A dishwasher drain hose end is 7/8" ID. It can be trimmed back to 5/8 ID.
The 5/8 fitting will go to the 5/8 inlet on air gap.
The outlet arm of the air gap is 7/8". This will go to disposal inlet, or a 7/8" branch tailpiece.
(make sure to knock out factory seal on disposal or you will have a flood, rather than water discharging into disposal, it will come out of air gap at counter)
Old 08-30-14, 11:45 AM
lawrosa's Avatar
Super Moderator
The OP is from Ohio...
Old 08-30-14, 12:15 PM
Handyone's Avatar
Air gaps are required by many plumbing codes (UPC - Uniform Plumbing Code is one) for dishwashers and for water softeners.
If it isn't a nationwide standard, it will probably become one soon. Air gap does a better job than loop in ensuring waste water from sink is not siphoned into dishwasher.
Old 08-30-14, 12:34 PM
lawrosa's Avatar
Super Moderator
Our plumbing code air gaps went out with the horse and buggie. They have not been required for years..
Ill have to check the UPC code because I thought it was all code now that no air gaps needed.
If you can quote that section from the UPC that would be great..
Old 08-30-14, 01:08 PM
Handyone's Avatar
OK Mike,
UPC 807.4
IRC Section P2717.1
But that said, let's just leave it for CA. I got a headache from looking at those notes.
I didn't mean to sound authoritative in my explanation. The chances of waste water backing into any dishwasher is slim. And as mentioned, many newer dishwashers have a built in loop.
CA has a rule for everything.
Old 08-30-14, 01:21 PM
lawrosa's Avatar
Super Moderator
Thats a stupid code IMO... But its probably left there for the homeowners benefit. As you see from the OP's issue the installer could not even get it right...
Here is the UPC code...
http://www.iapmo.org/UPC%20Report%20...apter%2008.pdf
We follow the national standard plumbing code.. Just NJ and maryland I believe...
No not at all.. I just did not feel like looking up the code and my trick to get you to find it worked...
Old 08-30-14, 01:33 PM
Handyone's Avatar
You're OK man.
Some of these codes don't make sense. I'm at the mercy of an inspector. Sometimes I feel like they have to find something just to make things interesting.
