Amana front loader error code 16
Good morning,
I've googled with no success, but did find this forum, so it wasnt all for naught!
I have an Amana Tandem 7300 showing error code 16
(MOD) NFW7300WW01
(SER) HL11662940
(TYPE) 832-A
I have cleaned the hoses and reset it. i have also put it on the cleaning cycle with vinegar.
Any help is much appreciated.
Thank you,
Christina
(MOD) NFW7300WW01
(SER) HL11662940
(TYPE) 832-A
Thank you,
Christina
For your info washer was built by Whirlpool, do not know that code most codes start with a F xx, What is the washer doing, not draining, no spin??
know all about dyslexia have it bad. Fairbanks may have the codes. Retired a few months ago and don't have access anymore. Does it drain? usually the drain pump is clogged when it won't spin. Take lower panel off you might find a tech sheet in panel or taped to side. Will have codes and how to test. Drain pump is the white thing with a screw cap in it. If you take cap off you will have about 6 to 7 gallons of water there. Is your washer on a pedestal? If not I always lean washer back against wall so water is in back and than I can put a pan under it.
