Washing machine fill valve
Old 09-03-14, 06:44 AM
C
The cold water supply to my GE washing machine began intermittently shutting off and eventually stopped all together. At first I could just turn the machine off, then back on and it would work fine. Then quit supplying cold water all together. I still have warm & hot water to tub. So I just assumed I needed to replace the fill valve. I replaced with a new fill valve and the new valve prevents all water from entering tub. No hot or cold. There is power to the valve and all connections are correct. Water supply lines are new and are supplying plenty of water to the valve. Any help would be appreciated.
Old 09-03-14, 06:53 AM
Received 1,121 Votes on 1,041 Posts
Welcome to the forums.
Are you using an actual meter to check for 120vac at the valves ?
A non contact test probe will not work properly.
Old 09-03-14, 11:38 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
please post model #.......
