Leaking kenmore fridge
Old 09-03-14, 05:39 PM
G
I have a kenmore fridge that is leaking water. Attached is a picture of the area where water has frozen above a drain. A few hours before I took the picture the frozen area was went. If I get a picture of that I ill upload that also. Anyhow why is this happening?
Old 09-04-14, 12:08 AM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
A model number would be helpful here.
A picture of ice by a drain doesn't help me much.
Is this just a fridge ? Usually only freezers have a drain plug.
Usually when you get water inside of a fridge it's due to a frozen/clogged defrost drain tube. There is a tray below the coil that directs the water, that occurs when the unit defrosts, towards the back of the fridge where it follows a drain line down to a drip pan over the hot compressor.
Old 09-04-14, 02:34 AM
G
The model number is C978-54168-1
Old 09-04-14, 05:58 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Kenmore model # will look like this XXX XXXXXXX First 3 numbers is manufacture and last numbers tell which ref. you have. Model # usually found in ref side toward top
Old 09-05-14, 03:26 PM
G
Here is a picture of the label where I got the model number.
Old 09-05-14, 11:46 PM
pugsl's Avatar
Canada my bad, Canada model # won't work in US. Not the ref. guy they may need different info than.
Old 09-06-14, 11:13 AM
I can't access Kenmore/Ca. products.
You left a picture above and said you had water. Is this in the fridge or the freezer ?
I also left you info in my first post.
