Whirlpool LSQ8543JQ0 washer stops after wash cycle
Old 09-10-14, 04:51 PM
Me and my girlfriend just moved into our new place, and with it came a Whirlpool Ultimate Care 2. I have no idea how old it is, but it seems to be in rough enough shape. Today we tried to use it for the first time (thank god we did a test cycle first). We put it on a normal wash, and it stopped about half way through the wash. So, it's full of water and full of soap. I can move the dial anywhere and it'll work properly unless its passed the wash cycle (i'm assuming). Anywhere from an inch before the rinse cycle, and then all the way through to the end I get nothing so it won't drain or anything. I got a light hum at first, but now I get nothing. Do we need to get a new washer?
Old 09-10-14, 05:02 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
Can you please post the model number for that Whirlpool machine. Lift the lid up and you'll find the ID plate at the bottom, just under the lid.
One particular problem that causes the most problems is the lid switch.
Old 09-10-14, 05:46 PM
The Model number is LSQ8543JQ0 (Last O is possibly a zero. Couldn't quite tell).
Update, though: It stops in the middle of the wash cycle, not after. And if I move the dial to the rinse section it takes about 5 minutes but it does eventually click on. It still hasn't drained, and it's stopped again a little bit into the rinse cycle but it did finally click on.
Old 09-10-14, 06:55 PM
F
Yes, last character is a zero. That washer is about 14 years old. Probably a bad lid switch. You can bypass it as a test. If that cures the problem, then replace it.
See video on how to bypass the switch. Your switch type is the second one in the video.
https://www.youtube.com/watch?v=XAnQ6Ovvnuc
Old 09-10-14, 09:45 PM
Pretty reliable washer. I have one the same age and in that series.
