Kenmore 80 series washing machine won't agitate
Old 09-17-14, 01:50 AM
I
I'm trying to find the cause of why our washing machine won't agitate. It only moves in either direction a few centimeters.
Its a Kenmore 80 series model# 110.92580100
Any help is appreciated and thanks in advance!
Old 09-17-14, 02:53 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Is the motor making noise? does it spin? Does it drain water?
Old 09-17-14, 06:41 AM
I
Motor is making noise, it spins and drains water fine
Old 09-17-14, 07:21 AM
F
Agitator is 2 piece. Bottom half is driven directly by the transmission shaft, top half is only driven in the clockwise direction by the lower half of the agitator. If it's just the top half that is barely moving, then you probably just need to replace the agitator dogs. Part number 80040. Go to youtube for many videos on this easy repair. Search on agitator dogs.
Old 09-17-14, 08:16 AM
I
Yes it is the top half that's not moving. Bottom is moving fine from what I can tell.
Thanks fairbanks and pugsl
Old 10-07-14, 11:22 AM
I
OK I'm having more issues now...
I ordered the parts but never got around to installing them. But now the machine won't spin while draining. It's making a loud noise but not moving. Any ideas fellas?
Old 10-07-14, 11:46 AM
pugsl's Avatar
Sounds like drive coupler. Visually check to see if agitates (open lid to see) if no agitate and spin and it fills and drains you need a drive coupler.
Old 10-07-14, 03:31 PM
I
It agitates just doesn't spin. Is there anything else I should check?
Old 10-07-14, 04:42 PM
pugsl's Avatar
Look inside cabinet about 6 inches from floor you you may see a streak of oil. If there you need a gearcase top seal, clutch and drive coupler. lean washer back against wall to look under it.
Old 10-07-14, 05:10 PM
I
OK I'll check it out when I get home. Not sure I completely understand what I'm looking for
Old 10-07-14, 06:43 PM
pugsl's Avatar
Your looking for a oil leak, Top seal in gearcase leaks and slings oil on cabinet.
