kenmore oasis elite (not HE) washer
Old 09-21-14, 06:29 AM
D
It all started with the F1 code. After much reading, I changed out the machine/motor control board assembly. Easily done. I did a load of laundry to test it out, and it ran as it should. Several hours later I went to do another load, and now it won't fill with water. It locks as it should and then I can hear a slight humming noise, but nothing happens.
What to do now?
Old 09-21-14, 07:14 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Did you get the tech sheet out from the front. If not lift top, not lid and on left side taped to front is the tech sheet. It will tell how to enter test cycle and how to check water valves. Make sure the water is turned on and the screen inside the cold water side is clean. screen is in the valve under hose. If you need help opening top let us know. Please post model # only way to find washer.
Old 09-21-14, 12:18 PM
D
Thank you for your response. I found the issue and all seems to be working now.
Old 09-21-14, 01:20 PM
pugsl's Avatar
Just to help any body else what was the fix? Thanks for the comeback.
