Whirpool oven is showing Broil on Bake and Broil functions
Old 09-29-14, 04:45 PM
L
Used the self-cleaning function last week on our Whirlpool self-cleaning oven Model RB5305PD86. When trying to use the bake function, the digital display says Broil 500. Top element comes one, bottom does not. The actual Broil function is working the same as it should be.
The bottom element never comes on.
Any ideas? Thank you
Lindymause
Old 09-29-14, 04:57 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
That is an odd problem. I would try two things....
First... disconnect power to the unit for a few minutes. Power it back up and test it.
If that doesn't take care of the problem... put it into self clean for a few minutes and then cancel it.
Old 09-30-14, 11:20 AM
L
PJmax,
Tried both. NO go. After the few minutes in self clean I did check and the bottom element did get hot.
Old 10-01-14, 12:33 AM
Is this a new stove ?
Had it been working ok ?
Some units use both heating elements for cleaning and oven preheating.
Can you double check the model number for me.
Old 10-01-14, 05:59 PM
L
It is 15 years old and has been working fine. The first time we used self clean I had to change out the thermo switch in the back,. The second time I used it, it was fine. This last time a friend cleaned it and the bake function disappeared and broil is there now twice.
Rechecked the model number and it is: RB5305PDB6 or R85305PD86.
The 8 could be a B or the other way around. It is hard to tell. Sorry.
Old 10-22-14, 03:27 PM
L
OK So I called the techs. Come to find out the ribbon to the control board had been loose. Resetting it has solved our problem.
Old 10-22-14, 05:46 PM
Thanks for stopping by and updating us.
