Maytag dryer drum will turn but not with a load in it.
Old 10-15-14, 06:29 AM
I have a 7 year old Maytag MED9600SQ0 dryer, I put clothes in it to dry and the motor makes a humming sound but the drum does not turn. I took all the cloths out and restarted the dryer. The drum will spin but acts like it has a soft start before coming up to speed.
I bought a new motor and installed it last night ($130.00 Ouch!), still same problem.....Help!!!
Old 10-15-14, 07:49 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Just to get it right in my mind. When you push start button you get a hum and than dryer will start, but with a load it just hums? Try this with a load in it tape door switch down , push start button and turn drum in direction of travel. If starts you have a bad motor again. Fairbanks may be in later and see if he has anything different to add. Standard Whirlpool HE dryer.
Old 10-15-14, 08:22 AM
Thank you for the reply, Yes! if I push the start button with door open and cloths in it then manual help the drum get started it will run. But it is a little stiff to get it started.
Old 10-15-14, 01:11 PM
pugsl's Avatar
Stiff when started is normal. Hope you bought motor where you can return it for another.
Old 10-19-14, 05:35 PM
Finally figured out what was wrong with the dryer. Found the neutral loose in the breaker box.
Old 10-20-14, 02:38 AM
pugsl's Avatar
Thanks for the update, Must of been a real pain to find.
