Heating element on dishwasher will not work
Old 10-23-14, 06:40 PM
A
I have aWhirlpool dishwasher. My heating element will not come on during heat cycle. I have checked element using a OHM meter and the element has current. I heard it has something to do with timer. Can somebody help me out?
Old 10-23-14, 06:48 PM
Tolyn Ironhand's Avatar
Received 209 Votes on 185 Posts
Welcome to the forums!
Please post the model number of your dishwasher. There should be a label some place with it.
Old 10-24-14, 08:17 AM
Received 1,113 Votes on 1,033 Posts
Your timer tells the heating element when to come on. If it's a mechanical timer then the timer actually turns on the element. If it's an electronic keypad then the electronics activate a relay which turns on the element.
A model number would be needed to continue.
Old 10-24-14, 04:07 PM
A
Model # DU1015XTXB3 and it is a Whirlpool Quiet Partner 1
Old 10-24-14, 04:11 PM
A
I just posted the model number.
Old 10-24-14, 04:57 PM
Videos illustrating testing and replacement of the element are located here...
Whirlpool Dishwasher Won't Dry Dishes - Model DU1015XTXB3 - Repair Clinic
Your unit uses a high limit thermostat. It will need to be checked for continuity.
You tube/watch?v=eeAU5HDpT28
Old 10-26-14, 02:32 PM
A
I have checked for continuity for the thermostat and element. Both showed continuity. Dishwasher is a little over a year old. You were saying something bout a timer being bad? Can you give me some more info on that subject? I also think the element was never working from when I first installed the dishwasher. I always thought that I had bought a dishwasher that didn't dry my dishes very good until the day I felt the heating element when it was on dry cycle and it wasn't hot.
