Kenmore circuit board fuse?
Old 10-27-14, 09:44 AM
the_tow_guy's Avatar
Received 55 Votes on 45 Posts
Reached into fridge this morning and noticed light was off. Further check and it's got no power. Outlet is live. Called for a repair tech to come later to check. Since they won't be out until between 4-7 I decided to carefully do some investigating. Discovered one of the two fuses on the main circuit board is apparently blown even though the fail-point is intact; guessing it has failed inside where the end of the element meets the end cap.
Question: Do I understand that the only fix for this is to replace the entire circuit board??? The fuse does not appear to be replaceable except by desoldering from board and getting a new one in. I briefly bypassed the fuse and the fridge fired right up.
Kenmore top freezer 795.79292.901
New board is about $190 from Sears, but I've found some lower including a reman for under $100.
So additional questions. (1) Is it likely the blown fuse is a one-time event, or does this need further troubleshooting to prevent blowing fuse on replacement board?
(2) Remann'd board a good choice?
Old 10-27-14, 09:55 AM
And just as an afterthought, why do they engineer stuff like this with non-replaceable fuses???
Old 10-27-14, 10:53 PM
Received 1,113 Votes on 1,033 Posts
That is kind of interesting. I haven't seen board like that before. Most don't use any fuses.
Usually a non replaceable fuse is considered catastrophe protection.
If it was me I'd try resoldering a new fuse in. You can buy them with wires on them. I make my own but you have to be real fast with the soldering iron or the link melts.
Old 10-27-14, 11:08 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
I'd put a new fuse on as well. RS carries the type with leads I think(?), and if your skills aren't up to it any electronics shop would probably do it for cheap.
Old 10-27-14, 11:27 PM
Field trip to New Jersey.
Old 10-28-14, 12:46 AM
F
Received 35 Votes on 27 Posts
They used to make a clip for those fuses that would then allow a regular fuse (without leads) to be used. Pretty common on televisions some forty years ago or so. I haven't the foggiest where to even begin to look for one.
Old 10-28-14, 04:16 AM
I have to say I made a pretty good fix, I think. Went browsing at RS for a holder and fuses. Found a holder I thought I could adapt but after getting back to my bench it looked like a struggle. In a flash of genius, I removed the terminals from the two holders and soldered them back to back to make piggyback adapters. Fridge has been happily humming away fro about 18 hours now. Check it out:
Name:  IMG_7741 (Large).jpg
Name:  IMG_7742 (Large).jpg
Name:  IMG_7744 (Large).jpg
Name:  IMG_7745 (Large).jpg
Old 10-28-14, 04:21 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
I like it. Keeps heat away from fuse.
Old 10-28-14, 12:21 PM
F
Excellent work, Tow. op[kvdoe[kmg
Old 10-28-14, 01:08 PM
dirtydickey's Avatar
Why not investigate why the fuse blew in the first place?
