Maytag fridge water leak
Old 11-11-14, 09:28 AM
I have a Maytag Model MBF2258XEB1 fridge. Bottom freezer. Only about 2 years old.
There is a small puddle of water sometimes on the floor in front of fridge. Also, the freezer floor gets alot of ice build-up. I disconnected the water line to the ice maker. Still have the problem. I suspect condensate is not being handled properly.
Where do I start looking for a fix? I'm pretty handy.
Thank you!
Old 11-12-14, 12:00 AM
Received 1,113 Votes on 1,033 Posts
Probably best to remove cover over the evaporator coil. The drain is usually directly below the coil and in your case..... appears to be clogged.
Old 11-12-14, 08:28 PM
Thanks for the suggestion. I will check this.
