Rebuilding a Jenn-Air stovetop cartridge
Old 11-18-14, 10:12 AM
V
Received 1 Vote on 1 Post
Hello ladies and gentlemen
My cartridge has parts no longer available - new cartridge is also not available.
Mine has 4 spades and a center round posts - newer ones have 3. Jenn-air says they are not compatible - internet folks say they are - so I decided to rewire it.
The no longer part I need is a piece of material - and that's my question, what is it? - that sits in between where the spades enter the ceramic block and the little metal frame that holds the whole thing in place when that little frame is screwed into the cartridge. It almost looks like a piece of circuit board, so could I buy a piece, number one, and cut it to go in there? Sound ok? Thanks
ps can't get the uploader to put a picture on here - sorry - that would be really helpful I'm sure....
Old 11-18-14, 10:17 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Old 11-18-14, 12:12 PM
V
i keep getting a failed message when i try to upload the pic. it's only 2 mb, don't know why
i moved it, renamed it, can't think of what else to try.........
jenn-air 87847 stainless cartridge. 4 spades on the front of the cartridge.
Old 11-18-14, 12:18 PM
Shadeladie's Avatar
Super Moderator
Received 119 Votes on 94 Posts
it's only 2 mb
Wow, that's huge! No wonder you can't upload it. You'll need to resize it.
Here's an online resizer that's easy to use or use Irfanview.
Web Resizer - Making Photos Faster - Optimize pictures for websites and email
IrfanView - Official Homepage - one of the most popular viewers worldwide
Old 11-18-14, 12:29 PM
V
my bad - Name:  stove_opt.jpg
ok that doesn't look like it worked either - says it's 76 kb
Old 11-18-14, 12:34 PM
V
it's the tan piece that's sitting on the post, one side is burnt
Old 11-19-14, 10:26 AM
V
hello
now I need help with the wiring - the front burner won't heat up
here is how I have it currently, but it must be wrong !
Thanks for your help. Name:  stove wiring 001_opt.jpg
Old 11-24-14, 03:20 PM
V
still need help with my jenn-air cartridge
hello and thanks
my jenn-air stovetop cartridge (old) with 5 wiring spades (4 flat and one round in the center) shorted out and i have all the new parts in but can't figure out the wiring. I currently have it wired like this: only the back burner works.
I appreciate your input.
Old 11-24-14, 04:49 PM
P
Temporarily Suspended
Old 11-24-14, 08:50 PM
Received 1,113 Votes on 1,033 Posts
I combined your new thread with this one. It's easier to keep the same problem in the same thread.
I'm confused here.
Your new cartridge has four electrical connections.
How many wires are there in your stove for connecting to the new burner assembly ?
Do you have a VOM (volt-ohmmeter) ?
Old 11-25-14, 08:58 AM
V
the stove has five (female) slots - the round center post and two on each side. Same as the cartridge (male). Jenn-air told me the newer cartridges weren't compatible with my stove. Newer ones have a center post, two on the left, ONE on the right. They said to rebuild the one I had, so I did. New wires, new ceramic block, etc.
I'm thinking I actually have it wired correctly, and now believe the stove female slot (the one on the side where the cartridge burned up) is where my problem lies.
Yes I have a VOM. thx
Old 11-25-14, 09:08 AM
Are you sure the elements in the cartridge you rebuilt are good ?
You should measure around 10 ohms between the red terminals.
You should also measure a similar resistance between the blue terminals.
The new three terminal cartridge combines one red line and one blue line on a common terminal.
Old 11-25-14, 02:56 PM
V
i checked the continuity of the elements - both are good. Then I swapped the wires and just the front burner worked, so I'm thinking this stove had two "hot" leads on the right and one is no longer working. Looks like how you have it shown above on the three terminal illustration will do the trick, and it was my next move. thank you
Old 11-25-14, 11:23 PM
I've illustrated the three terminal wiring connections but I don't know what the particular order is.
