Which inner door glass? Kenmore (Frigidaire) 790.92321301
Old 12-02-14, 01:01 AM
H
Hello,
This is a post I also put in a different forum. The moderator there thinks it is part #8. From the diagram and examining the oven door and broken glass, I think it is part #16, which costs at last twice. I don't want to take a chance and not be able to return the part or having the hassel of returning.
Could you give me your comments?
I searched sears parts and got this: DOOR Diagram & Parts List for Model 79092321301 Kenmore-Parts Range-Parts | SearsPartsDirect
From what I can see on my oven door, there are the outer door glass and two inner door glasses. The inner door closet to the racks is cracked. But the sears diagram shows three inner door glass: #5, #16 and #8.
So do I order part #16 (Part #: 316085701) or part #8 (Part #: 316088600)? It looked like I need part #16 but what is part #8.
Thank you for your help.
Old 12-02-14, 06:03 AM
Handyone's Avatar
It looks to me like it's #8.
If you're in doubt you can confirm you have 3 pieces of glass in door. #5 and 16 would be the outside glass and #8 the inside.
You can also call Sears and speak with a repair specialist. I have done this in the past. The repair department will confirm part you need. Parts department will transfer you to repair.
When reassembling door, be sure to use all rubber spacers and rubber washers. Do not over tighten the glass as it will shatter. It's tempered. Just snug up the screws.
Glass will shatter in a million pieces, please don't ask me how I know this
Old 12-13-14, 05:20 PM
H
Thank you very much.
I got the glass replaced and it was part #8. I did break some clips on the cap so I will replace that too and the cost is about $38. Haven't ordered the cap yet.
Thanks for all the help.
