GE PD968SP3SS Oven Gets Code F9- Control Circuit Area Overheats
Old 12-14-14, 10:39 AM
T
I've been reading the threads here and elsewhere regarding this issue, and it seems that the resolution is to replace the LIMIT SWITCH and SWITCH LIMIT components.
The parts are easy enough to find on this site, and both seem to be part of the Cooling Fan Parts sub-assembly. Parts for GE PD968SP3SS / : Cooling Fan Parts - AppliancePartsPros.com
My question is, where exactly is that assembly located?
Thanks in advance for any help!
Old 12-14-14, 10:55 AM
Received 1,119 Votes on 1,039 Posts
Welcome to the forums.
What is the problem you are having with your appliance ?
My GE trouble code list differs from what you've found.
F9 - This code usually means that a component has failed somewhere in the door lock circuit.
GE Range - Oven Error, Fault or Function Codes
