Whirlpool Duet Washer doesn't power on
Old 01-10-15, 03:28 PM
K
Our whirlpool duet washer will not power on. It was turning on and off multiple times by itself and then stopped powering on completely. Electricity works fine. When we took the top off, there were no loose or split wires. When disconnecting and connecting the CCU you hear a click. We tried to do the diagnostic test, and there was no response. Model # WFW9640XW00.
Please help. Thank you.
Old 01-10-15, 04:40 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Not to familiar with that washer, Where do you hear the click from? Here is a list of control parts
http://www.searspartsdirect.com/part...153200/W110412
Did you ever see a fXX code?
If you enter your model number The last drawing is part #1 motor control. Because you can't get it in the service mode Call sears and see if they offer a service plan for non working washers, It mat cost less than you can get parts for. If you can find a F code on tech sheet it will tell how to check.
