Whirlpool fridge - evaporator fan stays on
Old 01-12-15, 07:48 AM
F
I've got a Whirlpool side by side (ED5KVEXVQ01). Been noticing the fridge has been on the warm side. I finally investigated further and found thawed food at the top of the freezer. The whole rear of the freezer is frosted up and the fan was staying on.
Any advice? Is this a control board issue?
The timing seems coincidental since I just installed the water line. I'm not sure if I could've done something to cause this to happen.
Thanks
Old 01-12-15, 08:44 AM
F
I forgot to mention.... I found it curious that the filter light went out after I reset it also a few weeks back.
Old 01-12-15, 09:00 AM
Received 1,118 Votes on 1,038 Posts
I just went thru the wiring diagram and the condensor fan, compressor and evaporator fan should only run when the thermostat is calling for cooling.
Confirm the condensor fan is running down below when compressor is running.
Old 01-12-15, 09:29 AM
F
Thanks for the reply PJ.
Yes the condenser fan is running.
