Kenmore washer wont spin
Old 01-25-15, 09:31 AM
T
I have a kenmore washer model 110.20022012 it drains rinse everything when it's time to spin it does nothing no noise nothing just slince then after a while says cycle complete the lid locks and everything so I knw it's not a lid switch problem idk where to start since it makes no noise can someone please help me out
Old 01-25-15, 10:47 AM
Received 1,121 Votes on 1,041 Posts
Welcome to the forums.
This following video gives you an overview of your Whirlpool built washer. You need to put the machine into diagnostics. The diagnostic routine will point you in the right direction.
you tube/watch?v=LoO3G57RSno&x-yt-cl=84503534&x-yt-ts=1421914688
There is also a tech sheet under the front cover of the washer. Here's a link to that tech sheet.
appliance blog/attachment.php?attachmentid=13598&d=1384075737H
Here is another,non technical, video of your washer.
you tube/watch?x-yt-cl=84503534
Old 01-25-15, 10:57 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
One thing to check, Lean washer back against wall and look under it. There is a plastic cover over the pulley, if there is a groove cut in it take the cover off and get some loctite for the nut and reinstall it. First thing I would check but with no noise it's probably ok.
